Sulfuric Acid Reporting
Back in 2005, you responded to a question regarding the reporting of sulfuric acid in lead/acid batteries for SARA 302/311/312 reporting. You had estimated that sulfuric acid would be about 18% of the weight of the battery. Is this still a good estimate?
Q. Back in 2005, you responded to a question regarding the reporting of sulfuric acid in lead/acid batteries for SARA 302/311/312 reporting. You had estimated that sulfuric acid would be about 18% of the weight of the battery. Is this still a good estimate? G.M.
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 6th Quarterly Report
NASF/AESF Foundation Research Project #121: Development of a Sustainability Metrics System and a Technical Solution Method for Sustainable Metal Finishing - 15th Quarterly Report
