WASTEWATER SAMPLING
We have a small plating line and batch wastewater treatment system that are captive to our manufacturing operation. For many years, the city has allowed us to perform grab sampling from a sampling port on the side of our batch treatment tank for our compliance sampling. During the city’s recent annual inspection, they stated that EPA is making them require us to install a sampling manhole outside of the plant; this manhole will also require a weir or flume to allow collection of flow proportional samples.
Q: We have a small plating line and batch wastewater treatment system that are captive to our manufacturing operation. For many years, the city has allowed us to perform grab sampling from a sampling port on the side of our batch treatment tank for our compliance sampling.
This is also the same location that they perform their own sampling. During the city’s recent annual inspection, they stated that EPA is making them require us to install a sampling manhole outside of the plant; this manhole will also require a weir or flume to allow collection of flow proportional samples.
Not only is this structure very expensive to install because of the location and depth of our existing sewer, but we will also need to either buy or rent an automatic sampler/flow meter in order to obtain the composite samples for metals. We believe this is an overkill for our small operation, but the city says it is an EPA requirement. We have always had a good relationship with the city, but this time they seemed edgy. Our compliance record is good; we have sporadic violations on one or two metals, but our follow-up samplings have always shown compliance. Your thoughts. S.H.
A: Just like the military, government bureaucracies always like to bump to blame up to a higher level. What has likely happened is that your city’s industrial pretreatment program was recently inspected either by your state or region EPA and the city was found to be deficient in its implementation. One of the specific issues is how the city has allowed you to sample your batch treatment tank; EPA likely contends that its does not provide for a representative sample since the wastewater quality can change as the wastewater leaves the batch treatment tank.
What the city is not telling you is that, based upon changes to USEPA general pretreatment regulations several years ago, the city has more flexibility on how it complies with the regulation’s sampling requirements. Under USEPA general pretreatment regulations, 40CFR403.12(g)(3), it reads “...24-hour composite samples must be obtained through flow-proportional composite sampling techniques, unless time-proportional composite sampling or grab sampling is authorized by the Control Authority. Where time-proportional composite sampling or grab sampling is authorized by the Control Authority, the samples must be representative of the Discharge and the decision to allow the alternative sampling must be documented in the Industrial User file for that facility or facilities.”
As you can see, this language gives the city much leeway. Even under the old regulations, the language read “flow proportional sampling, where feasible.”
With many wastewater sampling projects, there are two major issues that the government regulators want addressed: sample representativeness and access. Let me propose several options that you can evaluate for your particular situation, and if appropriate, use to approach the city.
If your flow is small enough and you have the room, consider a batch discharge tank. For this option, you pump from your batch treatment tank to your batch discharge tank each day. After stopping flow to the batch discharge tank, mix it (aeration, mixer, recirculation pump) for a period of time to achieve a homogenous volume, and at an agreed upon time with the city, discharge tank while it continues to be mixed. During the discharge, take your grab samples for all pollutants. The batch discharge tank pretty much guarantees a representative sample. Also, this option allows you to continue to grab sample—no automatic equipment needed.
A second alternative is time-proportional sampling of your batch treatment tank’s discharge. By installing a p-trap on the tank’s discharge and using an automatic time sampler, samples can automatically be taken every “x” minutes during discharge. I would use a maximum time period of 15 min or at least four samples, whichever produces the most samples.
A variation of the second alternative is to pump out of your batch treatment tank at a constant rate through a p-trap and use an automatic time sampler to take a sample every “x” minutes during discharge. Since there’s constant flow and time interval, this would be considered flow-proportional sampling.
A fourth alternative is to construct a small weir box containing a 22.5 or 30° v-notch weir; this small box, typically constructed of PVC or polypropylene, is fairly inexpensive and can be located inside your facility. You will still need to purchase or rent an automatic sampler/flow meter.
To address the access issue—that is, the city’s ability to obtain a sample without entering your plant— I would propose a large cleanout be installed on the sewer from the plant. This is much less expensive than a manhole and gives the city access to obtain a grab sample for a quick check of your wastewater quality.
If your city still insists that they require an outside sampling manhole, I strongly recommend that you use a flume instead of a weir as your primary flow device. Over time, solids will collect behind the weir, and these solids contain regulated metals. Even if you sample downstream of the weir, a flow surge can stir up these solids, causing them to suspend and be sampled. I have participated in numerous compliance meetings with cities on this very issue. If there is sufficient slope in your existing sewer pipe, my first recommendation is to utilize a 1-inch Parshall flume; for a shallow slope pipe, my second recommendation is to utilize a 4-inch Palmer-Bowlus flume. These are standard fiberglass-constructed flumes available from a number of fabricators around the country.
I hope your past good relationship with the city helps them be reasonable in addressing your situation. Just keep in mind their need to satisfy the key issues of sample representativeness and access.
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 9th Quarterly Report
Read MoreHubbard-Hall Acquires BioConversion Technology
The acquisition adds experience and biologics to the AquaPure product line.
Read MoreNASF/AESF Foundation Research Project #121: Development of a Sustainability Metrics System and a Technical Solution Method for Sustainable Metal Finishing - 15th Quarterly Report
