Painting Q&A: Big Spray Paint Job
I am looking for equipment to spray a two-coat paint system on a large surface measuring approximately 30 × 30 ft.
Q. I am an engineering manager and am looking for equipment to spray a two-coat paint system on a large surface measuring approximately 30 × 30 ft. The first coat will be a conductive coating that will contain a high silver loading, and this will be followed by a clear coat. I want to use an application system that will lay the paint down fairly smoothly and has a spray pattern that will cover an area as large as possible. I was considering an airless spray outfit, but I am unsure of how it would handle the silver-loaded paint. What application system would you recommend? B.C.
A. Painting such a large object could be a big problem. Airless spraying would certainly work for both the silver-filled first coat and the clear coat. However, if the viscosity of the silver-filled paint is extremely high, you may have to use an air-assisted airless spray gun to get proper atomization. This spray gun, which uses compressed air for additional atomization, would be used with the airless spray outfit.
Looking to the Future of Finishing
Products Finishing takes a look at some of the ways the finishing industry is investing in workforce development and educational initiatives.
40 Under 40: Class of 2023
Products Finishing's 40 under 40 program recognizes nominated individuals driving the surface industry forward. Meet the class of 2023.
Beware the Employee Freeloader
Clearly communicate expectations, set goals, measure performance and trust your instincts.
