BORIC ACID AND MANNITOL
I am required to determine the boric acid concentration in our nickel sulfamate plating bath. Can you provide a procedure for doing this?
Q. I am required to determine the boric acid concentration in our nickel sulfamate plating bath. Can you provide a procedure for doing this? A.M.
A. Here is a procedure for determining the concentration of boric acid in a sulfamate nickel plating bath.
Procedure |
Pipette 5 mL of the nickel sulfamate plating solution into a 250-mL Erlenmeyer flask. |
Add 50 mL of deionized water to the flask. |
Add 5 g of mannitol. |
Add 5 drops of bromocresol purple indicator to the flask. |
Stir thoroughly and titrate with 0.1-M sodium hydroxide to a light blue end point. |
The volume of sodium hydroxide (X) needed, in mL, is used in the following equation. |
X mL x 1.24 = g/L of boric acid. |
Boric acid is a “weak” acid and gives a poor “end point.” Adding mannitol to the flask changes the weak acid into a stronger acid, which gives a good, clear endpoint in the titration with sodium hydroxide.
For those of you there who are not organic chemists, mannitol is an organic molecule that is a combination of a sugar and an alcohol. A drawing of the structure taken from Wikipedia is shown below.
