Electrocoat As a Primer
Question: Since electrocoat is used so extensively as a primer in the auto industry, how can it be used as a primer in other industries?
Since electrocoat is used so extensively as a primer in the auto industry, how can it be used as a primer in other industries? Does it improve the performance of powder coating when used as a primer? M.M.
While the development of electrocoat as an automotive primer has progressed, all of the advantages provided to the auto industry can be used in many other industries. The current cathodic epoxy automotive primers (as well as several previous generations) provide excellent corrosion protection as stand-alone coatings and provide corrosion enhancement as a primer.
Almost all automotive electrocoats are applied over zinc phosphate pretreatment with chromic acid seals to maximize corrosion protection. The electrocoat material provides such good corrosion protection that it can also be used in place of high-performance pretreatment. Minimum pretreatment, all the way down to single stage neutral cleaner/coaters, two- or three-stage power washers or wand-wash pretreatment are acceptable for electrocoat (with some reduction in corrosion protection). As long as parts are clean (blasting or pickling are also acceptable), they will coat. The epoxy resin system provides the corrosion protection. The newer electrocoats are also capable of dry film thickness (DFT) of 2 mils or greater compared to the original automotive electrocoats, which were 0.8 mil or less. Also, remember that the transfer efficiency of electrocoat is 95% or more.
When I was involved in electrocoating as a custom coater, we regularly competed with zinc plating on a cost-per-part basis as long as the parts were rack (not barrel) plated. Corrosion protection was also comparable, based on salt spray. We also had several cases where customers were able to fabricate parts from CRS versus zinc-coated steel. This also provided them with the secondary benefit of not having to deal with the problems of welding the zinc-coated substrate.
Electrocoat is an excellent primer for powder as well as liquid topcoats. The only warning that I would make, based on experience, is to check intercoat adhesion and physical tests such as impact and conical mandrel. The epoxy electrocoats are quite hard (4H-5H pencil hardness) and some topcoats have trouble “getting hold” of the electrocoat. One possible solution, if this is a problem, is to under-cure (dehydrate only) the electrocoat as long as the cure temperature of the topcoat is sufficient to finish curing the electrocoat. All but the low-cure powders should provide an adequate final cure for both coatings.
Another use of electrocoat as a primer that we promoted as a custom coater was to only topcoat the exposed portion of the product. Parts such as agricultural tractor grille screens were electrocoated first and powder coated back-to-back with a polyester powder to provide the UV protection desired. The back-to-back powder coating meant getting two parts for the price of one as far as line density and powder use was concerned. The electrocoat provided 100% uniform coverage of all the perforated holes and the powder provided the UV protection with little plugging of some very small holes. Electrocoat also provides penetration into “nooks and crannies” that are hard to reach with powder or liquid. Again, as a primer, the electrocoat provides the corrosion protection with the topcoat providing color only. The only limitations in this area of using electrocoat is the problem of air pockets or “puddles” with the electrocoat process requiring immersion of the parts.
Titrations: To Automate or Not to Automate?
What considerations should you keep in mind for automatic titrations? Conor McAnespie of Hanna Instruments discusses the benefits of auto titrators.
Read MoreEcoat — An Entrepreneurial Approach
Read MoreCoatings Plant Evolves with Market Trends
Read MoreTin and Tin Zinc Overview and Growth
Brett Larick of Columbia Chemical discusses the increasing demand for conductive finishes driven by the increasing electrification of vehicles.
