Have a Blast Cleaning Parts
The concept of the wet blasting process in parts cleaning and surface finishing is straightforward enough: combine abrasive media with water to form a special slurry, then add regulated compressed air to control the pressure as it is discharged over a surface.
It is a dust-free and static-free process that removes burrs, scale, oxidation and rust, marks, paint, and coatings. It can also remove oils and grease while performing other functions such as preparing the surface for other coatings or processes.
Today, matte finishes are a popular choice for parts—often for both practical and cosmetic reasons. Automated slurry-blasting machines are a great choice for achieving fine, non-directional matte finishes in a single operation. Depending on the application, profiles of less than 4 Ra are possible, and users can choose from various media, including glass beads, ceramic or plastics.
The slurry-blast process virtually eliminates embedded media issues commonly found in dry blasting systems. The water and slurry are recirculated, requiring no drain hookup. The process does not create dust, and chemicals are not required, adding to its appeal for manufacturers committed to limiting their environmental impact.
Controls And Monitoring
Finding the right slurry blasting equipment, however, as well as achieving and constantly maintaining the desired results depend heavily on controlling and monitoring several specific machine functions. Ensuring consistency in terms of media, air and water pressure are critical to precise and consistent finish results.
The following guide outlines key considerations and recommendations when selecting slurry blasting machines:
Part Fixturing: Finding a method to hold the part firmly and in a consistent position in the blast stream is essential and will require the end-user and blast equipment vendor to work together to identify the best solution. Part fixturing can be combined with masking techniques to protect surfaces that do not require a profile.
PLC-Controlled Machine with Operator Interface (HMI): This important aspect provides part process and machine parameter setup, and editing and saves the parameters to form part process “recipes.” Part processing is accomplished through enabling the assigned recipe number. The control system must monitor all machine parameters during the process cycle as well as the machine shutdown and status/fault display on the HMI screen.
Machine Configurations: Consistent process results require that the developed part-to-blast stream relationship be repeated cycle after cycle. There are several ways to control the process by manipulating the part. Most often, the fixture part rotates on a powered table with fixed nozzles targeting specific areas. The part can also be manipulated in front of blast streams with a robot, or a robot can manipulate the nozzles. In any machine configuration, the part or nozzle movement must be monitored in real time.
Part Rotation within the Blast Streams: Look for a VFD-controlled drive system where the drive is external to the cabinet and uses a belt and sheaves. In addition, a zero-speed sensor located on an idler sheave will confirm table rotation and help ensure even, consistent coverage.
Media Concentration Control: Low-level warning sensors for the slurry concentration are an important feature to ensure a precise and consistent result. If the media concentration falls below the set percentage, more media is automatically added from the hopper. The system should allow for roughly three additions of media, but if concentrations remain too low the system should trigger a shutdown and display warning.
Media Size Control: Media within the slurry must be the correct size. Look for equipment with a hydrocyclone, which separates the slurry stream into two outlets: one with the fine particles and water, and the second with the large particles, typically the remaining good media. The large particles are returned to the machine sump, while the fines are sent to a vibratory classifying screener where a screen recaptures any good media and returns it to the sump. The remaining water and smaller particles are sent to the moving bead filter where the water is separated from the particles and recycled back into the system as rinse or makeup water.
Slurry Pump Flow: Water pressure should remain within +/- 3 psi. Water pressure sensors are an indirect but effective way to ensure the slurry flow is being generated by the pump. In addition, if the slurry pressure exceeds the set tolerance, the sensor should trigger a machine shutdown and display a warning.
Startup and Continuing Slurry Agitation: These are essential to ensure the media and water are forming a homogeneous solution ready for the blasting operation. The machine sump holding the water/media must continually agitate the slurry during the blast cycle. We recommend a pre-process agitation cycle provided by the machine supplier, especially important if the machine has not been operated for several hours.
Nozzle Pressure Control: Air pressure from the nozzle should remain within +/- 1 psi. An automatic, proportional air valve is important to maintain the pressure programmed in the recipe and sent to the blast guns. This control process will shut down the machine and trigger a fault if the pressure falls out of tolerance.
Operator Viewing Window: Provides the operator the opportunity to look into the blast cabinet and observe the blast cycle in operation, allowing additional process verification and troubleshooting if required.
Process Testing Apparatus: A method to test, process and confirm the correct nozzle-to-part relationship is also extremely important. Testing can be accomplished with laser light fixtures that fit into the nozzle orifice. The laser beam shows the blast stream’s target point on the part. This makes routine inspections, adjustments and fine tuning straightforward and repeatable.
Finally, never underestimate the value of a factory-trained local representative for your process equipment. Part availability, preventive maintenance and trustworthy after-sales service go a long way in ensuring your process equipment and operations are running reliably and efficiently, and provide precision matte finishes time after time.
Rick Roth is product manager for blasting at Rosler Metal Finishing USA LLC. Please visit Rosler.com for more information.
Pretreatment of Black Oxide
Read MoreReplacing Open-Top Vapor Degreasing in Aerospace Manufacturing
Options and considerations for cleaning aerospace parts as regulations tighten on vapor degreasing solvents.
