How Phosphates Impact Your Discharge
Phosphate conversion coatings are used to impart corrosion resistance, lubricity or to serve as a base layer for subsequent coatings. Hubbard-Hall’s Robin Deal explains their environmental impact.
Q: What impact is the use of phosphates having on the discharge from my finishing operation, and what else should I know about the ramifications?
A: Phosphates are salts of phosphoric acids. Phosphorus is derived from the Greek “phÅsphoros,” meaning “morning star” or “bringer of light.” It is the 15th element in the periodic table and is essential to all life, with the average human body containing 25.6 ounces (751.3 g). It is found in products ranging from kitchen matches to conversion coatings for corrosion resistance (as phosphates).
Phosphate conversion coatings on metals are used to impart corrosion resistance and lubricity, or to serve as a base layer for subsequent coatings, such as paints, dyes and more. In simple terms, the process solution consists of a phosphate salt in a solution of phosphoric acid. The immersion process is commonly applied to steel parts, but is also applicable to other metallic substrates, including zinc, cadmium and tin, among others. The conversion coating consists of a phosphate of the substrate metal (for example, iron phosphate in the case of steel).
In addition to surface finishing applications, phosphate chemistry is widely used in commerce, including agriculture and other areas. Accordingly, phosphates in process wastewater can produce serious problems in the environment, the most harmful being eutrophication.
Eutrophication is caused by excessive phosphorus in water. In rivers and streams, eutrophication can result in serious algae blooms, from which harmful toxins are derived. A few of the more serious consequences are fish kills, odors, foul tastes in the drinking water supply, visual unpleasantness and closed public lakes in recreation areas.
The Clean Water Act of 1972 gave the U.S. Environmental Protection Agency (EPA) permission to establish guidelines for water and wastewater, including phosphates. The EPA established standards for the wastewater discharge of phosphates to receiving bodies of water as follows:
- Streams and rivers — 0.1 ppm
- Streams entering lakes — 0.05 ppm
- Lakes and reservoirs — 0.025 ppm.
The EPA guidelines for nutrient management recommend that publicly owned treatment works (POTWs) charge surcharges whenever the following limits are not met:
- Biochemical oxygen demand (BOD) limit of 210 ppm with a surcharge of $0.232 per pound
- Total suspended solids (TSS) limit of 230 ppm with a surcharge of $0.186 per pound
- Total nitrogen limit of 30 ppm with a surcharge of $1.17 per pound
- Total phosphorus limit of 12 ppm with a surcharge of $1.32 per pound.
An industry is given a permitted amount of phosphorus they can discharge (for example, 15 lbs./day with a total discharge flow of 150,000 gal/day (GPD)). To convert pounds to parts per million (ppm): ppm = lbs. of chemical / 8.34 x MGD (million gal/day). For example, 15 lbs./day at 150,000 GPD, 1 /8.34 x 0.15 MGD = 11.99 ppm. This means that 12 ppm of phosphorus can be discharged to meet the permit. Anything more can carry a surcharge per EPA recommendations.
Phosphorus Removal: There are today two primary technologies for phosphate removal from wastewater — chemical and biological.
Chemical Removal: A number of chemical agents have been used to remove phosphorus from wastewater. In an alkaline solution, calcium reacts to form calcium carbonate. At pH ≥ 10, the excess calcium bonds with phosphorus to precipitate as a hydroxyapatite. Copperas (for example, ferrous sulfate) or iron bonds with phosphorus to form iron phosphate, which easily precipitates out. Alum, or more commonly potassium alum, KAl(SO4)2•12H2O), works much like calcium, but its usage will be based upon removal requirements. Current research in our laboratory is underway involving new technology. This technology has a long track record of proven success and is readily available, cost effective and affords ease of operation.
Biological Removal: Certain bacteria are capable of storing phosphorus as a polyphosphate and are referred to as polyphosphate-accumulating organisms (PAO). These systems involve different setups, depending on the type of bacteria. In industrial applications, biological removal is used as a “Final Polish” to achieve permit limits. Research is also being done on biological phosphate removal. This technology has been shown to be an efficient means of phosphate removal. There are multiple types of systems to choose from and training is readily available to new operators.
The ultimate goal of all of these efforts is a clean environment. For example, a Hypoxia Task Force currently involves 11 states and the EPA working together to reduce the size of the Gulf of Mexico’s dead zone. This zone comprises the largest hypoxia zone in the United States. The task force was established in May 1998 with a charter. Members consist of federal, state and tribal representation, and they are diligently working to solve this serious problem.
Elsewhere, industries are driving research for better practices from nonphosphate cleaners to alternatives to phosphate coatings. Nonphosphate cleaners are being developed and widely used. Zirconium is replacing phosphate in paint preparation lines. Phosphate recovery systems are being utilized and new technologies for phosphate lines are close to industrial use.
Beyond these efforts, each state is working on a tailored nutrient management plan for recovery of impaired waters.
Robin Deal is a wastewater field service technician with Hubbard-Hall. Visit hubbardhall.com
Read MoreReduced, Reused and Recycled Powder Coatings Are the Future
Read More12 Ways to Improve Your Powder Coating Quality
