Hubbard-Hall’s Chemistries Designed to Replace Traditional Solvents
SUR/FIN 2021 exhibitor Hubbard-Hall designs aqueous and solvent chemistries to reduce the cost, complexity and chemical consumption of surface cleaning.
![Hubbard-Hall’s Chemistries Are Designed to Replace Traditional Solvents](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/PF/2021-PF/hubbardhall-surfin2021.jpg;maxWidth=720)
At SUR/FIN 2021, Hubbard-Hall will showcase its aqueous and solvent chemistries that are designed to replace traditional solvents like nPB, TCE and PCE/PERC. Hubbard-Hall says it is committed to reducing the cost, complexity and chemical consumption of surface cleaning. The company’s display features Aquaease 2289, which reduces cleaning steps, Aquaease Infinity, which reclaims 95% of cleaners and Dualene, which is the first pre-stabilized, modified alcohol developed for metal cleaning.
Hubbard-Hall | 855-405-6123 | hubbardhall.com
SUR/FIN 2023 Registration Is Now Open
The National Association for Surface Finishing SUR/FIN 2023 surface finishing industry trade show will take place June 6-8, 2023 in Cleveland, Ohio.
Tin-Zinc Alloy Electroplating and Its Corrosion Behavior
An NASF/AESF Foundation Research Program Retrospective
