Keep on Truckin’ with the Right Coatings
The Raymond Corporation knew it wanted the latest technology available. The question was a little more complex: liquid or powder for its coating applications.
The Raymond Corporation (Greene, NY) has been a leading material handling company in North American for more than 90 years, and also an integral member of the Toyota Materials Handling Group.
Their success can be attributed not only to innovative products – like the first hydraulic hand lift truck in 1934 and the first narrow aisle truck in 1951 – but also to their ongoing mission to improve their customers’ operations.
So, when it came time to analyze and upgrade the efficiency of its own finishing process, the company knew it wanted the latest technology available. The question was a little more complex: liquid or powder for its coating applications.
They ended up going with the latter, and worked with the Nordson Corporation (Amherst, OH) to install the new powder coating system.
“Our volume was increasing, and we needed to find a solid finishing system to support our production goals,” says Jim Jackson, manufacturing engineer at the Raymond Corporation. “Originally, we were set on another liquid system, but months of due diligence revealed a better solution. Our paint team evaluated at least 10 options before settling on powder coating and Nordson.”
Prior to working with Nordson, Raymond used an air-dry liquid paint system with conventional conveyors, a two-stage washer and liquid spray equipment. Even though the finished product had a tough durable paint, the system had several issues.
“The biggest concern was the time it took the paint to air dry,” Jackson says. “After painting, the parts cured on a cart and were susceptible to finish damage during cure time.”
Once parts were dry to the touch, but not fully cured, they made their way to the assembly operation where they were further subjected to finish damage. This led to increased costs due to the many handling precautions required, as well as a significant amount of rework.
According to Jim Kadlec, Raymond Corporation’s manufacturing engineer, the company set several goals for its new powder coating system: 1) increase production capacity, 2) lower coating cycle times, reduce rework, and 3) improve the product finish quality.
“Nordson’s powder coating system promised to achieve all these goals and one more,” says Kadlec. “Powder coating helps us decrease our environmental footprint by increasing transfer efficiency, reclaiming powder and eliminating hazardous air pollutants in our formulation.”
Raymond’s operation requires that they coat very large parts. The part window for the system is 6-feet wide by 6-feet tall by 16-feet long. What’s more, with considerable mass (such as with 4-inch-square, heavy gauge steel tubing used for outriggers and very heavy counterbalance weights), Raymond needed the best available technology for their particular operation. In addition, 80 percent of its production is coated black, with 20 percent a mix of red and orange.
Evaluating these specifications, Nordson recommended a two-booth powder coating. The first booth is a Nordson Excel 3000 cartridge powder coating booth outfitted with Sure Coat automatic guns for the black powder; the other booth contains two Prodigy HDLV (high-density powder, low-velocity air) manual spray guns for red and orange powder.
Other powder coating operation components include a five-stage washer/pretreatment system, environmental room, power-and-free conveyor system and a five-lane convection oven.
“This was a very challenging project with respect to available floor space and the curing of the extreme range of part thicknesses. We spent a lot of time in our customer lab getting it right,” explains Mark Horton, regional sales manager for George Koch & Sons, the system house that coordinated all the finishing components.
“Reaching part-to-part consistency was the real challenge because there were varying thicknesses in the metal components. But, Raymond is a stickler when it comes to quality, and there was no compromising,” Horton says.
Three rounds of testing at the Koch facility with different powder formulations from Valspar was imperative to a successful implementation. In addition, the project also included the powder coating of a complete lift truck for testing at the customer’s facility.
When used to apply the black powder, Kadlec says Nordson’s Sure Coat automatic guns provided Raymond with an efficient, versatile and operator-friendly application tool. He added that the guns have a design that lends itself to fast, easy cleaning without gun disassembly for reduced downtime.
Jackson says transfer efficiency is maximized in the system with Nordson HDLV technology. This includes a dense-phase pump and two Prodigy manual spray guns, which are used for reinforcement in some of the tougher-to-reach recesses and tight corners. He says Nordson HDLV technology moves more powder with less air and higher transfer efficiency than conventional venturi-style pumps. This results in a softer spray, larger fan pattern, even pattern distribution, and less powder consumption.
“We’re saving about 50% in material costs over what we spent in liquid paint for the same amount of trucks,” explains Kadlec.
Other benefits Raymond received with the new system include:
• Cleaner parts with the five-stage washer compared to the old two-stage system
• A 40% reduction in load bar cycle times
• The ability to produce about 9,000 trucks per year in a single shift operation versus about 7,500 in a two-shift operation
• A 100% cured finish on part components when they come out of the oven
• More durable finish over liquid coating
• Reduction in waste
Another significant improvement is the reduction of labor and WIP that Raymond has eliminated by implementing a new two-tone process for their tractor bodies. Kadlec has led a team to create a process in which both the red and black can be sprayed in the booth at the same time. When the truck leaves the powder system, both red and black are 100% cured in one cure cycle and ready for the assembly line.
But Jackson and Kadlec both agree: the single greatest benefit of their new powder coating system is the uniform finish they are achieving.
“The finish we’re getting now is so consistent and durable that we actually eliminated the whole touch-up process. And rework labor has been almost eliminated completely,” says Jackson.
For more information on Nordson, please call 800-626-8303, or visit www.Nordson.com/powder.
Learn More
Lubricating Powder Coating Systems
To read about how to select a lubrication system for a powder coating operation, visit http://www.pfonline.com/articles/129801.html
Heat Up Your Maintenance Plan for Best Oven Performance
Improve efficiency and profitability with a preventive maintenance program for your industrial heating equipment.
Read More‘Warming Up’ to the Truth about Ovens for Surface Treatment
Understanding the different types of oven heat technology for surface finishing, including how they work, and their advantages and disadvantages, can help determine the best heating solution for an application.
Read MoreCuring Oven Basics
