Plating Clinic: Cleaner Bath Life
Q. My cleaners are not lasting nearly as long as they should. What can I do to lengthen the life of my cleaner bath?
Cleaner Bath Life
A. There are a few things that will affect the life of your cleaner baths. The first concerns the condition of parts that you are putting into the bath. If the parts are dripping with oil/grime, your cleaner isn’t going to last very long because it will have a lot to clean up. This is easily fixed by lowering the amount of oil used to ship or manufacture the parts. Note that this may not be possible if you aren’t in charge of manufacturing the parts, so I recommend you discuss this with those who send you the parts. Additionally, depending on the type of cleaner you are using, adding a weir to your cleaner tank may help lengthen bath life by removing oil from the top of the bath.
The quality of the water being used can also affect the cleaner bath life. Each of the broad categories of water, hard, soft and purified water, have different properties that may affect the bath life.
Examples of hard water includes well water, pond or lake water and river water. Because it contains a lot of dissolved minerals that can prevent the cleaner from pulling the oils and grime into the solution and off the surface of the part, hard water is the worst for bath life. The easiest way to think about it is that there can only be so much “stuff” in solution at one time. Soft water is just hard water that has had many of the minerals removed from it. Since soft water has fewer dissolved minerals than hard water, cleaner baths made with soft water tend to last longer when compared with hard water baths. Purified water is just what it sounds like, soft or hard water that has been purified. Like soft water, there are several different ways to make purified water. Baths with purified water will last the longest, due to the fact that nearly all of the dissolved minerals have been removed, leaving pure, clean water.
The type of cleaner may also affect the life of a cleaner bath, though this will vary case-by-case. There are many types of oils and compounds used to manufacture parts, and for every oil and buffing compound, there is a surfactant or soap that will clean it. For instance, paraffinic oils can be very difficult to clean.
However, there are cleaners designed to remove these oils from the surface of the part. Talk with the oil supplier and cleaner supplier to find the best solution and check at what temperature the cleaner should run—oftentimes, cleaners will have a range at which that they can run. It is important to make sure the cleaner is in that range to get the best cleaning. While it may not affect bath life directly, it can improve the cleanliness of the parts.
Short cleaner bath life can be a frustrating problem, especially if you feel you aren’t getting your money’s worth out of the bath. Keep in mind that your cleaner is the first line of defense for your plating line. It is designed to be used up and trashed so that your plating solution isn’t chewed up by the surface contaminants. The best thing you can do is talk to the supplier if you are struggling with bath life. They will help you target your efforts to lengthen bath life.
Jake Fisher is with Asterion. For information, visit asterionstc.com
Read MoreNASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 12th Quarterly Report
This NASF-AESF Foundation research project report covers the 12th quarter of project work (October – December 2023) at the University of Georgia. In our previous report, we described our work on performance and effect of surface fluorinated Ti4O7 anodes on PFAS degradation in reactive electrochemical membrane (REM) mode. This quarter, our experiments involved utilizing porous Ti4O7 plates serving both as anodes and membranes. Tests compared pristine and F-18.6 Ti4O7 anodes at current densities of 10 mA/cm2 and 40 mA/cm2. This 12th quarterly report discusses the mechanisms of the effects on EO performance by anode surface fluorination.
Read MoreNASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 5th Quarterly Report
Read MoreHubbard-Hall Acquires BioConversion Technology
The acquisition adds experience and biologics to the AquaPure product line.
