KCH Engineered Systems
Positive Energy Growth
Chrome Deposit Corp. reduces its energy use, minimizes its environmental impact and improves its energy-management practices.
Tucked away in a nondescript industrial park off the I-95 corridor, Chrome Deposit Corp.’s (CDC) Newark, Del., manufacturing facility is a small site that is making big changes in the way it saves on energy costs.
The Delaware Manufacturing Extension Partnership (DEMEP)—a nonprofit resource organization that provides technical field agents and consultants to help Delaware manufacturers improve their productivity and profitability—identified CDC as a potential candidate to receive an “Energy Savings Assessment” through the University of Delaware’s Industrial Assessment Center.
CDC executives partnered with UD’s Center for Energy and Environmental Policy and the U.S. Department of Energy’s Industrial Technologies Program (ITP) to explore ways to reduce its energy consumption and environmental impact—while continuing to expand its facility’s operations.
With a few inexpensive, easy changes to infrastructure and preemptive management of operational processes, CDC has been able to reduce its energy costs by 25 percent per unit, minimize its environmental impact and continue to seek novel solutions to its energy-management practices.
Energy and Environmental Challenges
CDC reconditions finishing work rolls, which require grinding, chrome plating and texturing. The rolls are used on rolling mills to provide superior finishes on both steel and aluminum sheets. CDC has seven locations across the U.S. The company’s Newark facility specializes in hard chrome plating and electro-discharge texturing of the product surface prior to plating.
While industry standards, certification requirements and customer demands help to drive improvements in energy efficiency and technology, economic pressures facing the industry often result in companies seeing their most viable option as retrofitting existing technologies as opposed to making wholesale process changes.
Working with hard chrome during the plating process holds inherent environmental implications. Not only must CDC contend with byproduct air emissions and waste, but the plating process itself is energy intensive—relying on both electrical and natural gas resources to fuel operations.
Electricity represents about half of the finishing industry’s energy costs, with purchased fuels (primarily natural gas) comprising the remaining portion. In a 2006 study, the metal fabrication industry consumed 41,965 trillion kWh and 234 billion cu ft of natural gas that year, which equates to the total annual energy consumed by 762 billion households, or the annual primary energy consumed to provide electricity to 1.11 trillion households.
Implementing Energy Efficiency Recommendations
Since production began in 1986, CDC has tracked its energy usage and costs, keeping pace with its growth. In a judicious effort to enhance its portfolio of responsible business practices, CDC initiated an Energy Savings Assessment through DOE-ITP’s Industrial Assessment Center program.
In addition to the assessment, CDC’s management group began its own energy efficiency initiatives to focus attention on operating practices, operations-related water usage and reductions, and increasing the fuel efficiency of its truck fleet.
As seen in Exhibit 1, results of the energy assessment pointed to six distinct areas through which technological and process improvements could capture energy savings in both quantity and cost. Of the recommendations, CDC pursued the implementation of four and is planning to employ an additional recommendation over time as upgrades to equipment are required. The only recommendation CDC declined to implement required process automation and the installation of specific process controls. The company’s management group thoroughly investigated these alternatives and consulted with industry experts before electing not to implement the recommendation.
Reducing Natural Gas Consumption
One of the improvements CDC observed during this time was a reduction in natural gas consumption. The assessment team recommended an analysis of stack gases from the boilers used for heating chrome tanks and wastewater evaporation. The analysis revealed that the boilers were burning rich, which prompted technicians to adjust boiler settings in order to achieve the recommended burn ratios.
Shortly thereafter, CDC employees discovered that the savings from this change were actually higher than the study initially estimated. The immediate success of this simple manipulation caught the attention of CDC executives, and within weeks the facility’s gas lines were being checked for proper functioning. This inspection exposed a number of small joint leaks. Repairs were made, and additional fuel savings were realized. After implementation, CDC’s natural gas usage decreased by 12 percent despite increased production.
Reducing Water Usage
Another impressive outcome of CDC’s energy efficiency efforts was a drastic reduction in water usage. Initially, CDC’s rectifiers were cooled by city water. The company’s management group authorized the capital purchase of two chillers and implemented a closed-loop system to cool heated components. The result: an 85 percent reduction in water use.
CDC approached energy efficiency with some trepidation. While the company’s management group embraced the concept and the will to mitigate its environmental impact, they were not prepared for the straightforward assessment and analysis process, nor had they truly anticipated the quickness with which they would realize results.
Although total energy expenditures increased by 5 percent from its 2007 data baseline, electrical usage was reduced 18 percent per unit and natural gas usage declined 35 percent per unit. Ultimately, CDC’s cost per unit showed a decrease of approximately 25 percent from both energy sources combined.
The facility’s success is now being used as a benchmark within the company’s network of plants. The Newark site’s energy efficiency efforts have not stopped here; the management group has set its own internal goals of increasing the miles per gallon of its truck fleet by 5 percent and purchased mud flaps that are expected to reduce the underside drag on the trailers, which will ultimately increase fuel mileage.
“The audit process suggested by DEMEP and conducted by the UD team was very helpful in pointing out deficiencies,” says John Blasko, general manager. “We had considered pursuing some improvements before, but this made us aware of the magnitude of available savings. Now everyone in the plant is energy conscious and looking to eliminate waste.” n
For more information about the U.S. Department of Energy’s Industrial Technologies Program, please visit eere.energy.gov/informationcenter.
Luster-On Products
PMTS 2025 Register Now!
management
PPG Appoints Multiple Employees to Leadership Roles
PPG has appointed several employees within to new leadership positions.
management
Attentive Employees Support Large Customer Base
As a Products Finishing Top Shop, this company’s success with offering a variety of finishing services would not be possible without its employee dedication and the pride that’s been instilled in them to produce quality products for its long list of customers.
Electroplating
Umicore Metal Deposition Solutions Names Managing Director of Electroplating Business Line
Michael Herkommer has been named managing director of the electroplating business line at Umicore Metal Deposition Solutions.
sustainability
Practical Environmental Management Reduces Costs, Refines Quality
By focusing on effluent treatment and efficient tin recovery, this Indian surface treatment plant meets stringent environmental standards and sustainable high-quality production.
Parts Cleaning
Parts Cleaning
