Powder Coating Clinic: Oil Seeping out of Large Welded Tubing
Q. We have a large part made out of tubing that is welded together. The tubing has a lot of oil seeping out of the welds when the part is heated and causes a defect in the cured film. We cannot get the oil out of the tubing in our washer. We tried cleaning up the defect and running it again, but oil still runs out. How can we get that oil out of the tubing?
![](https://d2n4wb9orp1vta.cloudfront.net/cms/Roger_web_1.jpg;maxWidth=600)
A. Oil is a necessary surface contaminant when steel is processed and shipped to lubricate it during processing and to protect it from rust during shipping and storage. If it is on the outside of a part, we use a combination of heat and chemistry to break it from the surface and flush it away prior to coating. But, if it is inside a welded tube, we have no method to remove it. In some cases, the volume is high enough to cause seepage from the inside of the part like you describe. Based on your description, you do not have any practical method to remove the oil. You cannot get a cleaner inside the tube and drain it back out. You cannot apply pressure to the cleaner inside the tube to help scrub it away. You can use heat, but it will take a very long time to boil it all out, and you may still have small defects. The only way the oil can be effectively removed is before the part is welded together. The manufacturer will need to clean the parts or have another source clean the parts before they assemble it. If they remove the rust inhibitor from the outside of the tubing, they may need to apply a light coating of oil or phosphate to the surface to protect it until it can be coated.
Originally published in the December 2016 issue.
Heat Up Your Maintenance Plan for Best Oven Performance
Improve efficiency and profitability with a preventive maintenance program for your industrial heating equipment.
Data Logger Helps Industrial Ovens Cut Energy Costs
Industrial Physics' encourages customers in the industrial coatings sphere to consider the energy saving properties of its oven logger kits.
Catalytic Gel Ovens Offer Small Operational Footprint
WolfRayet catalytic gel ovens offer small operational footprints while also providing a way to improve on existing convection curing.
