Removing Air Bubbles
Question: I am having problems eliminating air bubbles in radiator support which have 90- degree angles.
I am having problems eliminating air bubbles in radiator support which have 90- degree angles. The e-coat plant is an indexed system with the hoists only moving up and down, what do I do to remove the air bubbles? Do I increase pump circulation? P.T.
Install solenoids (non-lubricated) and compressed air cylinders to rock from side to side. Contact points must be isolated with Teflon®.
You might also try redesigning your racking so that it will give you a tipping action when it goes into the tank. There are several ways to do this. Talk it over with your fixturing people.
HTE Powder Coatings Take Coverage to the Next Level
High-transfer efficient powder coatings deliver cost, time and energy savings.
Film Thickness Control
A look at how poor rack maintenance contributes to wasted time, wasted chemicals and wasted materials.
