Seeing Inside Nooks and Crannies for Auto Corrosion Protection
Fischer Technologies (Windsor, CT), a manufacturer of coating thickness, material testing and material analysis instrumentation, has introduced a new, non-destructive flexible probe which they say can get inside normally inaccessible cavities to get measurements.
Most automobiles are provided a corrosion protection by a cathodic dip priming method, but that usually means OEMs have to trust their processes when they can’t get inside girders, stiffeners or cross beams to measure coatings.
But Fischer Technology, Inc. (Windsor, CT), a manufacturer of coating thickness, material testing and material analysis instrumentation, has introduced a new, non-destructive flexible probe which they say can get inside normally inaccessible cavities to get measurements.
The new V3FGA06H probe was specifically designed for the automotive industry. It has a curved shape and a small, flexible probe head that fits through small openings in the car body to measure coating thickness at areas which were tough to reach up to now.
Flexible and Smart
“Because of the flexible probe head’s smart kinematics, a precise placing and measurement is guaranteed, whether in blind mode or on beveled areas,” says Fischer’s Paul Lomax.
Fischer says the new probe is suited for measurement of cataphoretic painting typically thinner then 20 μm, including zinc coating.
“We’ve improved measurements on curved walls because of the free-moving angle of the probe head,” Lomax says. “And it also avoids scratching the coatings because of the lack of sharp edges on the plastic probe head.”
The new probe can measure defined distance from the insert hole up to 170mm. The minimum diameter of the hole is 14mm (or 15mm with a backstop) or 12mm with a slot hole.
The probe head has three points, so it can automatically find the correct position.
Lomax says: “This leads to excellent reproducibility and repeatability.”
The new cavity probe is compatible with Fischer’s FMP magnetic induction gauges, along with its Dualscope 100 for more heavy-duty use.
Non-Destructive Measures
The FMP Series is a hand-held instrument to measure coating thicknesses non-destructively. It uses a magnetic induction method or eddy current, and some devices use both methods.
Fischer’s FMP models are good for repetitive measuring applications that get lots of use and wear. The FMP30 and FMP40 feature various adjustments for structured data collection, more memory and are Bluetooth-data transfer capable, making them more suited for complex measuring applications.
Fischer’s most advanced model in the FMP family, the Dualscope FMP100, has a user-friendly operation and a high-resolution color touch screen that uses the Windows CE operating system. It also uses magnetic induction and eddy current measuring methods, and specific settings and calibrations can be stored and recalled later.
In addition to extensive evaluation and statistics functions, the FMP100 offers a graphical presentation of the measurement data through the use of its integrated FDD software package.
Fischer has products such as the Feritscope FMP30 for the measurement of ferrite content in austenitic and duplex steel. Other Fischer products include the Phascope PMP10 for measurements according to the phase-sensitive eddy current method; Phascope Duplex to measure individual thickness values of paint/zinc/steel coating in automotive and appliance settings; the SR-Scope RMP30 to measure copper coatings on computer- boards; Sigmascope SMP10 to measure electrical conductivity of metals such as aluminum or copper; the Anotest YMP30-S for testing the sealing quality of anodic coatings on aluminum to measure its weather resistance; the Fischerscope HM2000 and Picodentor HM500 to determine the Martens Hardness in the micro- and nano-ranges; and the universal measurement system Fischerscope MMS designed for coating thickness and materials testing according to the magnetic, magnetic induction, eddy current, beta backscatter and electrical resistance measuring methods.
Probe Workhorses
The real workhorses are the extensive high quality probes Fischer offers. While the probe supplies the actual measurement signal, the quality of the measurement is contingent on the correct probe selection for the application. Fischer offers several hundred varieties for different applications in coating thickness measurement and material testing.
Its magnetic induction measuring probes comes in four models, with a measuring range from 0–2,000 µm for electroplated coatings or paint and lacquer coatings. These are mostly used for measurements in bore holes, pipes or grooves applications, and some models have a two-tip probe for greater repeatability precision on rough surfaces, allowing for more reliable positioning and constant pressure force, even on soft coatings.
Fischer’s eddy current probes are suited for paint, lacquer or plastic coatings on non-ferromagnetic metal substrate materials. One model has an angle probe for measurements on flat specimens or in pipes, bore holes and interim spaces.
The company’s dual probes for measuring both magnetic induction and eddy current methods switch automatically to the appropriate method and are used for the measurement of single coating thicknesses. Paint/zinc on steel sheet or on steel structures are measured with the duplex probe. It is also possible to measure hot-dip galvanized coatings (Zn ≥ 70 μm) with diffusion zones. n
To learn more about Fischer Technology, please call 860-683-0781, or visit fischer-technology.com.
NASF/AESF Foundation Research Project #121: Development of a Sustainability Metrics System and a Technical Solution Method for Sustainable Metal Finishing - 8th Quarterly Report
This NASF-AESF Foundation research project report covers the eighth quarter of project work (January-March 2022) at Wayne State University in Detroit. The major activities in this report period are: (1) the development of a sustainability assessment method for technology evaluation with case studies, and (2) a continuous development of a software tool for sustainability assessment.
Read More5 Things to Know About XRF Calibration
The proactive approach of validating measurement performance and calibrating only as often as necessary improves quality, consistency and reduces costs.
Read MoreMulti-Functional Coating Test Instruments Operate Like “Swiss Army Knives”
With greater flexibility than limited traditional equipment, modern analytical instruments can ensure reliable coating performance by measuring critical characteristics like friction, peel, wear, and scratch resistance.
Read MoreSmart Modeling and Simulation of Electroplating Systems for Real-Time Monitoring of Chemical, Water and Energy Consumption (NASF Summer Research Grant)
An AESF Foundation summer research grant provided an excellent opportunity for a PhD student to learn how to use chemical engineering fundamentals to scientifically characterize an electroplating process through integrated dynamic modeling and simulation, and how to develop digital twin (DT)-based virtual plant that can be of any process configuration. This is a critical step for the investigation of new technology development for smart and sustainable manufacturing in the surface finishing industry.
