Sizing an Oven
Question: What size burner do I need to heat a 3,000 ft3 oven?
What size burner do I need to heat a 3,000 ft3 oven? P.T.
The burner for a particular oven is sized using several design criteria. These criteria are oven volume (ft3), oven surface area for heat loss (ft2) and oven load (lb/hr and product material). You only gave me the oven volume. Of all the criteria, this is normally the least important. For instance you can have a relatively small oven heating a large amount of oven load (parts and conveyor tooling), meaning it has a short cure time and a high line speed. In this case, the most important criteria to size a burner is the oven load. I forgot to mention that the temperature differences (for example, from 70-375F) along with the oven load are combined to size the burner. Buy an oven from a reputable supplier instead of modifying or building a homemade one. Then you don’t have to worry about the size of the burner, since they would have designed that for you.
Data Logger Helps Industrial Ovens Cut Energy Costs
Industrial Physics' encourages customers in the industrial coatings sphere to consider the energy saving properties of its oven logger kits.
Specialty Oven’s Hot Benefits and Other Questions Answered
Learn about the advantages of gas catalytic infrared pre-gel ovens in this article, including how they are energy efficient and can save users time and money when integrated into their existing systems.
Wicket Ovens Making a Comeback
