Stainless Steel In-line Mist Eliminators
Stainless steel in-line mist eliminators on display at SUR/FIN 2021
![](https://d2n4wb9orp1vta.cloudfront.net/cms/brand/PF/2021-PF/midwestair2021.png;maxWidth=385)
Midwest Air Products Co., manufacturer of PVC and polypropylene pollution control equipment, will exhibit stainless steel in-line mist eliminators. Available in 304 or 316 stainless steel, now mist elimination is available for high temperature and/or chemistries not typically compatible with thermoplastics. Particulate removal efficiencies of approximately 99% to 6 microns.
Midwest Air Products Co., Inc. | 231-941-5865 | midwestair.com
NASF/AESF Foundation Research Project #122: Electrochemical Approaches to Treatment of PFAS in Plating Wastewater - 10th Quarterly Report
