Stenner S Variable Series Metering Pumps
S VARIABLE metering pumps feature remote start and transfer and three dedicated output relays.
Stenner Pump Company manufactures peristaltic metering pumps. The new S VARIABLE features remote start and transfer and three dedicated output relays. The S SERIES interfaces with process control systems, has three programmable output relays and multiple modes of operation. Both variable speed pump series feature backup pump capability, tube leak detection, a totally enclosed housing and flow rate output up to 60 gpd at 100 psi. The CLASSIC are robust, electromechanical pumps with flow rate output up to 40 gpd at 100 psi. All pumps offer tube replacement without
tools. Stenner maintains a three-day lead time.
Stenner Pump Co. | 904-641-1666 | stenner.com
Pretreatment of Black Oxide
