Coating PVC Foam Boards
I am interested in coating PVC foam boards with paint. I heard that vacuum coating is a process that will work for this application. Can you direct me to a company that can either supply the equipment to vacuum coat, or provide the service to vacuum coat?
Q. I am interested in coating PVC foam boards with paint. I heard that vacuum coating is a process that will work for this application. Can you direct me to a company that can either supply the equipment to vacuum coat, or provide the service to vacuum coat? E.S.
A. Simply stated, in this process, the moving product passes through an application chamber that is evacuated. Both ends of the chamber are sealed except for openings the same shape as the cross section of the product. The paint is pumped into the chamber completely surrounding the product. Owing to the relationship between the entrance and exit openings and the product the paint film thickness is maintained automatically. It should work for foam board components. Suppliers of the coating equipment can be found through a web search for “vacuum coating” or by visiting the Society of Vacuum Coaters’s website svc.org.
Replacing Open-Top Vapor Degreasing in Aerospace Manufacturing
Options and considerations for cleaning aerospace parts as regulations tighten on vapor degreasing solvents.
Vapor Degreasing Cleaning Fluids for Precision Cleaning
Tergo XCF2 cleaning solution is designed to meet diverse industrial technical cleaning needs with formulas that deliver reliable and repeatable cleaning performance.
Solar Atmospheres of Western PA Receives Nadcap Accreditation
The company received the accreditation for it’s new, fully integrated Vacuum Oil Quench furnace, which provides a significantly cleaner and safer oil quenching process.
