Job Plater Keeps EN Plating Quality High
Bath and process control are key to quality for this New Jersey plater..
When your plating operation services a large spectrum of industries, not only do you have to be versatile, you have to be good. Paramount Metal Finishing Co., Linden, New Jersey, prides itself on the quality of its work, its state-of-the-art technology and its full-service plating operation.
Michael Fuschetti, vice president of operations, describes the finishing company as "a large job shop operation that emphasizes bath and process control as the most important aspects of running a high-quality electroless nickel operation." The company plates medical equipment, machine parts, electronic component packages, connector shells, computer components and aerospace parts.
A variety of substrates are plated on the four electroless nickel (EN) lines, using both racks and barrels. Plating on aluminum and steel alloys each represent about 40 pct of EN production. Zinc die-castings represent about 10 pct, with the remainder applied to special alloys used in the aerospace industry such as Invar, Kovar, stainless steels and coppers.
Key Decision
"We had been using a variety of EN suppliers before we made the decision to increase our EN capacity," Mr. Fuschetti said. "When market demands for more cost-effective electroless nickel plating and technical demands for high-, medium- and low-phosphorus electroless nickel coatings on more exotic substrates became evident, we decided to go with Fidelity Chemical Products." For the past five years Paramount has worked closely with its EN chemical supplier to tackle these difficult jobs.
Four EN Lines
To optimize production, Paramount employs four electroless nickel lines to accommodate the various shapes, sizes and substrates to be plated. The largest process line includes a 1,000-gal medium-phosphorus bath for plating aluminum alloys and other non-ferrous metals.
The line has the capability of handling parts as large as 10-by-six ft and is equipped with barrels that have a 500-lb capacity. This is the "workhorse" bath because of its economy and stability.
This bath is specifically formulated to provide an easy-to-operate, seven to nine pct phosphorus electroless nickel deposit. A stabilizer system provides for consistent brightness over the life of the solution.
The high- and low-phosphorus baths are on the other lines, which are equipped with fine mesh barrels and racks for critical work such as air-bag components, medical instruments and electronic packages. Light metals, such as miniature zinc die-cast connectors, are run on a separate processing line with specialized cleaning cycles, strike baths and post plates. These lines contain tanks that range in size from five to 500 gal.
The high-phosphorus system has a special stabilizer and buffering system that provides an ultra-smooth, non-magnetic coating. The compressively stressed deposit features excellent corrosion and stain resistance. It resists 1,000 hrs salt spray (ASTM B-117) at one mil thickness.
The low-phosphorus bath is a compressively stressed process that provides a hard electroless nickel deposit with excellent corrosion resistance in alkaline environments. The hardness is close to that of stress-relieved hard chromium. Also, the deposit is uniform enough that post plating or grinding may be eliminated.
Working toward ISO-9002
Paramount has made a commitment to continuous quality improvement, establishing a quality system based on the ISO 9000 series. It is taking the final necessary steps to qualify under ISO 9002, and hopes to be officially certified this year.
Procedures for analysis and scheduled maintenance are strictly adhered to in all cleaning, pickling and electroless nickel plating baths. Automatic programmed processing on linear plating lines maximizes plating efficiency. On manual hoist and prototype lines, detailed travel sheets accompany all work, dictating process cycles to the line operators.
An automatic controller makes additions to the high-phosphorus bath. The controller continuously analyzes for nickel metal and pH and makes replenishments as needed. X-bar and R-charts are used with statistical process control SPC software to control chemistry within set operating parameters. Coating thickness is measured with a computerized x-ray fluorescence system.
Zinc die-casting expertise. What separates Paramount from many other finishing shops is its extensive experience with zinc die-cast parts. "This is a metal that is sometimes difficult to activate and achieve good adhesion of the nickel plate," Mr. Fuschetti noted. "We can plate this in two ways. One way is to plate it with a copper strike followed by electroless nickel. The other is to plate electroless nickel directly onto the zinc die-cast."
The alloy type determines the pretreatment method. Zinc die-castings are used extensively in fiber optic connector shells for the communications industry where it has replaced conventional ferrous machined parts. "The reason for this," Mr. Fuschetti said, "is because it is a more cost-effective approach. The electroless nickel provides an excellent barrier to corrosion while being able to deposit uniformly on complex-shaped parts.
Another forte of the company is its work with aluminum. "This was considered a tricky material to plate," Mr. Fuschetti explained. "We do not consider it tricky any longer." Today the technology is there that dispels that belief. Forty pct of the company's work is aluminum. A few years ago it was only 10 pct.
According to Mr. Fuschetti, Paramount provides three main finishes, electroless nickel, tin alloys and zinc and zinc alloys, which represent 90 pct of the company's plating business. In addition, they perform robotic painting, powder coating, screen printing and assembly operations.
Paramount has developed a versatile, full-service plating operation that stresses excellent results and fast, cost-effective work even with difficult projects. And they back it up with a warranty on their work.
Table I-Operating Conditions for Low-Phosphorous EN | ||||
Parameter | Range | Optimum | ||
oz/gal | g/liter | oz/gal | g/liter | |
Nickel Metal Content | 0.64-0.8 | 4.8-6 | 0.72 | 5.4 |
Sodium Hypophosphite | 3.2-4.5 | 24-34 | 3.7 | 28 |
Temperature F | 180-120 | 190 | ||
pH | 6.0-6.6 | 6.2 | ||
Loading (sq ft/gal) | 0.1-1.0 | 0.5 | ||
Plating rate (mils/hr) | 0.5-0.8 | 0.6 | ||
Agitation | Continuous | |||
Filtration | Continuous five micron or smaller, six solution turnovers per hr |
Table II-Operating Conditions for Medium-Phospouous EN | ||||
Nickel Metal Content | 0.64-0.8 | 4.8-6.4 | 0.80 | 6.0 |
Sodium Hypophosphite | 3.2-4.2 | 24-34 | 4.0 | 30 |
Temperature F | 180-205 | 190 | ||
pH | 4.6-5.2 | 4.9 | ||
Plating rate (mils/hr) | 0.6-0.9 | 0.8 | ||
Filtration | Continuous three to five micron or smaller, six solution turnovers per hr |
Table II-Operating Conditions for High-Phospouous EN | ||||
Nickel Metal Content | 0.65-0.85 | 4.8-6.4 | 0.80 | 6.0 |
Sodium Hypophosphite | 3.2-4.5 | 24-34 | 4.0 | 30 |
Temperature F | 180-200 | 190 | ||
pH | 4.4-5.2 | 4.9 | ||
Loading (sq ft/gal) | 0.1-1.0 | 0.6 | ||
Plating rate (mils/hr) | 0.4-0.6 | 0.5 | ||
Defining a Top Shop: Quality, Quickness, Communication, Community
Luke Engineering & Anodizing Co. takes an active role in its community and the industry while also focusing heavily on the quality of its work and employee treatment.
Read MoreVideos: 40 Under 40 Class of 2024
In these uncertain times, it is refreshing to hear from and learn about young talent in the surface finishing industry who are striving to make a difference within their organizations and the industry as a whole.
Read MorePowder Coating Week 2023 Moves Industry Education Forward
Powder Coating Week 2023 offers can’t-miss powder coating industry education, networking opportunities.
Read MoreAttentive Employees Support Large Customer Base
As a Products Finishing Top Shop, this company’s success with offering a variety of finishing services would not be possible without its employee dedication and the pride that’s been instilled in them to produce quality products for its long list of customers.
