New Coating Could Mean Cheaper Solar Cells
An MIT website says a novel way to make thin, uniform coatings developed at Rice University could reduce the cost of making conventional silicon solar cells, and could open the way for new kinds of solar cells that are far more efficient or cheaper than conventional ones.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/uploadedFiles/Natcore.jpg;maxWidth=600)
Read more here: http://www.technologyreview.com/energy/39415/?p1=A1
Pulling Out All the Stops
