PPG Aerospace Coatings Add Character To Cathay Pacific Special Livery
“The Spirit of Hong Kong” livery on Cathay Pacific Airways’ Boeing 777-300ER airplane painted to support the “Hong Kong: Our Home” campaign.
![](https://d2n4wb9orp1vta.cloudfront.net/cms/PPG_Cathay.jpg;maxWidth=600)
Coatings by PPG Industries’ aerospace business create the colorful characters and “The Spirit of Hong Kong” livery on Cathay Pacific Airways’ Boeing 777-300ER airplane painted to support the “Hong Kong: Our Home” campaign of the Hong Kong Special Administrative Region Government.
The livery features a dark green fuselage with silhouettes of the 110 winners in an online contest calling on Hong Kong people to submit creative entries that illustrate the true spirit of the city.
Eight custom colors of Desothane HS/CA 8800 buffable topcoat by PPG Aerospace were applied over Desoprime HS/CA 7700 primer and waterborne chromate-free DesoGel EAP-12 conversion coating and adhesion promoter pretreatment. The high-solids formulations of the topcoat and primer result in a lower percentage of volatile organic compounds (VOCs).
“With an aircraft as visible as ‘The Spirit of Hong Kong,’ it was important for Cathay Pacific to have confidence that it would be a showpiece as it flies around the world,” said Kent Wong, technical services manager, Cathay Pacific. “Having worked closely with PPG Aerospace, we knew we could count on their products to perform and on their people to provide the exceptional service we needed.”
“PPG Aerospace was honored to help Cathay Pacific create the special livery,” said Terence Cheng, PPG coatings segment manager, Hong Kong. “Cathay Pacific has long been a PPG Aerospace coatings customer, and PPG supplied coatings for the first and second ‘Spirit of Hong Kong’ liveries as well.”
Cheng said the PPG Aerospace application support center in Suzhou, China, worked closely with Cathay Pacific to produce paint samples for color matching as well as the blended coatings. “With eight colors needed in a short time period, the PPG Aerospace team at ASC-Suzhou worked quickly to provide the samples and specific size packages of the blended paints.”
The aircraft was painted by Taikoo Aircraft Engineering Co. Ltd. in Xiamen, Fujian, China.
PPG Aerospace is the aerospace products and services business of PPG Industries. PPG Aerospace – PRC-DeSoto is the leading global producer of aerospace sealants, coatings, and packaging and application systems. PPG Aerospace – Transparencies is the world’s largest supplier of aircraft windshields, windows and canopies.
Water Wash Filtration
Snapshots of the finishing industry.
