Reading a Type II Dry Film Thickness Gage
Q: What should I look for when comparing gages? Testing and measurement expert Rob Weber from Fischer Technology provides this answer.
Q. I’m confused about Type II dry film thickness (DFT) gage specifications. Some manufacturers show an accuracy specification and some a trueness specification. Some show the gage repeatability, others do not. What is more
important: accuracy, repeatability or trueness? What should I look for when comparing gages?
A. That’s a very good question, because terms such as accuracy, precision, repeatability, trueness and so on are often misunderstood, interchanged or used incorrectly. Each of those criteria is important in understanding a gage’s true performance. When looking to compare different gage solutions it’s important to understand what those criteria mean.
ISO 5725-1:1994 is an excellent resource to gain additional information on this topic. This standard goes into great depth on the subject, but I will distill it here:
- Accuracy – the closeness of agreement between a test result and the accepted reference value.
- Precision – the closeness of agreement between independent test results obtained under stipulated conditions.
- Repeatability – precision under repeatability conditions, conditions where independent test results are obtained with the same method on identical test items in the same laboratory by the same operator using the same equipment within short intervals of time.
- Trueness – the closeness of agreement between the arithmetic mean of a large number of test results and the true or accepted reference value.
(Reference: ISO 5725-1:1994 Accuracy (trueness and precision) of measurement methods and results — Part 1: General principles and definitions)
In other words:
- Accuracy – how close a measurement is to the real (or accepted) value.
- Precision – how close together measurements are within a group.
- Repeatability – consistency between groups of measurements measured the same way, on the same part, by the same person.
- Trueness – the closeness of the average of a large number of measurements to the actual, or true, value.
Graphic analogies can be helpful to describe this visually. Something else to consider to ensure accurate measurement is the quality of the calibration standards used for field adjustment and gage verification. With DFT gages, you’ll often hear the terms calibration “foils” or “shims.” These are typically plastic, polymer or metallic standards labeled with thickness values.
It is important to consider the quality, or tolerance, of the calibration (adjustment) standards used with the gage. The tolerance of the standards needs to be included in the measurement value. In other words, the most capable gage available, calibrated and adjusted to standards with a tolerance of ±20 percent, can only be considered to be accurate to ±20 percent.
Where and how does this affect the user of a DFT gage? For example, a project theoretically requires 50 gallons of paint to meet a minimum dry film thickness of 5.0 mils. Using ±20 percent calibration standards, the contractor must apply the coating to a thickness of 6.0 mils to compensate for the standard’s tolerance and meet the specification’s minimum true thickness of 5.0 mils. Using standards with a ±5 percent tolerance enables the contractor to coat closer to the true required thickness, only needing to apply the coating to 5.25 mils to meet the 5.0 mil minimum thickness requirement.
Gage A (using ±20% standards) |
Gage B (using ±5% standards) |
Paint to a true thickness of 5.0 mil |
60 gallons (5.0 mil + 20%) |
53 gallons (5.0 mil + 5%) |
Cost of paint | $4,500 | $3,975 |
Savings from simply using better standards? $525 |
Another consideration for calibration standards is to look for not only the tolerances, but also for traceability of the standard. Is the calibration standard traceable to an accredited laboratory? Standards, traceable to a recognized organization, are helpful in demonstrating and proving a measurement device is working correctly and providing trustworthy readings.
The bottom line, or the moral, for this is story is to look beyond a simple “accuracy” specification and also look to a gage’s trueness and repeatability specifications as important criteria in comparing measurement systems. Another factor in measurement performance is the quality, tolerance and traceability of the corrective calibration standards used for gage adjustment.
About the Author
Robert Weber
Rob is an applications and product support engineer with Fischer Technology. Visit fischer-technology.com.
Shedding Light on Surface Inspection
State-of-the-art reflector-based lighting system improves luminosity and ergonomics for surface inspection tasks while reducing energy usage.
Read MoreSmart Modeling and Simulation of Electroplating Systems for Real-Time Monitoring of Chemical, Water and Energy Consumption (NASF Summer Research Grant)
An AESF Foundation summer research grant provided an excellent opportunity for a PhD student to learn how to use chemical engineering fundamentals to scientifically characterize an electroplating process through integrated dynamic modeling and simulation, and how to develop digital twin (DT)-based virtual plant that can be of any process configuration. This is a critical step for the investigation of new technology development for smart and sustainable manufacturing in the surface finishing industry.
Read MoreUpdated Aluminum Finishes Documents Suite
AAMA 2063, 2064 and 2065 have been updated to help users make informed decisions about the types of aluminum finishes they need for their projects.
Read MoreMastering Uniformity Through Surface Prep Standardization
By standardizing surface preparation processes and adopting surface energy measurement, a company can achieve uniformity, quality and cost reduction.
