Electrocoating Fasteners
What are the equipment and coating options for coating and curing fasteners?
Q. My company is looking into the possibility of installing an electrocoating system for fasteners. What are the equipment and coating options for coating and curing fasteners? Thanks in advance. J.W.
A.Coating fasteners has several challenges. While they can be coated in baskets using monorail or square transfer systems by placing the parts in a “pile” or a single layer (much lower production level), problems include:
- Parts stick together or exhibit variation in coating thickness if too many parts are in the “pile”
- Parts with internal threads can have typical “air pocket and puddle” problems
- Cleaning the baskets to ensure ground- ing contact with only a single or few layers of parts, due to the lack of weight of parts.
The problem of threaded parts was covered in my September 2002 Clinic. Parts sticking together and cleaning baskets can be improved by removing the baskets after the post rinse and dumping the parts onto a belt type oven.
While any e-coat color and resin system can be used on fasteners as long as the fasteners are clean and can establish contact, black cathodic epoxy is the most popular e-coat for automotive and other applications where corrosion protection is the major criteria. No major automotive company has approved bulk coating at this time, but the coating and equipment suppliers are working on an acceptable combination. It is probably just a matter of time until it is developed.
Non-automotive parts are being coated and cured in new square transfer barrel-type systems. The parts are rotated throughout the pretreatment, coating and curing processes. The coatings being used have been developed to minimize damage of the coating during curing and provide some “healing” of contact marks.
Installing an Ecoat Line
Looking Back to Look Forward
